Nuovo dal polacco-Settant'anni No`293
krzychu.pl
Operation and Programming webasto
Webasto Manual Peugeot 406
The clock selector 24 - Webasto
Introductory Programming heater:
Warm start time can be precisely set from 1minuty to 23godz 59 min.
Duration of the inclusion of the pre-selection or immediate or heating may be 59 or 29 min.
With the right kind of connection when you start an immediate heat button it is possible to work permanent.
Appropriate type of electrical connection is marked with a cross through the installation workshop.
duration of 59 min incorporation
duration of the inclusion of 29 min
work has on the ignition (clamp 15)
work was in the position of ignition radio / garage (clamp 75)
work has a lasting connection with the plus (clamp 30)
Setting the Clock Selector
Insertion time clock
Run time of the day (tagesziet) and at the same time forward (Vorlauf> or backward Rà¼cklauf).
Tip:
The longer the faster przebiek pressing digits on the clock.
Polling time clock
Press the time of day (Tageszeit).
Heating on / off
Press the heat immediately (Sofortheizen)
Inclusion indicator light is lit.
Heating off:
Restart the immediate heat button
Programming the beginning of heating:
Run the "1". Time preselection Vorwahlzeit
Run forward button (Vorlauf) or backward (Rà¼cklauf) until the field appears displaying the required time.
The number 1 is displayed.
Standby indicator lights up.
The "2" allows you to set a second time preselection.
Run the "2" pre-selection time? (Vorwahlzeit)
Activating the first time pre-selection is cleared.
Activation of the second pre-selection time is displayed on the indicator number 2
Setting the second time as the pre-selection takes place for the first time.
Time control preselection:
Briefly press the "1" preselection time (vorwahlzeit) 1 or 2 times pre-selection "2".
At the rate displayed is the time pre-selection and number designation.
Deleting prefetch time.
Briefly press the "1" until the pre-selection or "2" pre-selection time
The figure marks fade and ready indicator on the display.
You can also ask for additional installation in good company "WEBASTO"
Perform such services.
http://www.webasto.it/azienda/it/html/9230.html
In Poland there are companies that offer sales and installation of Webasto heating for each car
http://www.ebac.pl/
http://allegro.pl/webasto-ogrzewanie-wo ... 01683.html
Tip:
Polling time clock
Heating on / off
Heating off:
http://www.ebac.pl/
Bob Muttley ha scritto:
Unluckly in Italy it's impossible to find, do you think it's possible to find it on some broken 406 up there in Poland? Consider that our famous Ade from England neither knew about its existence..
If it happens that you find it somewhere could you let me know? Thanks a lot!
Ps APPELLO PER MODERATORI: SPOSTARE IL TUTTO IN APPOSITO TOPIC SUL FORUM TECNICO, GRAZIE!
OK OK
:D
OK OK
OK OK
:D
ammazza non si scherza qui:D:D
OK OK
krzychu.pl
Looks like needing around 2000 Euros to get a new one ready on the car.[B)]
I'm thinking of finding and getting a heater plug... works the same, very very cheap.
But finding one for the HDi isn't easy...
which have in common glow plugs to topic Webasto
from what I could to figure out the cost of installation of the new Webasto is around 2500 euros,
is it worth it? Respond themselves
No Way to spend all that money.
Anyway it was a good optional to get on a brand new car;
Being lucky maybe can get a used one (if they're all the same for every kind of 406) for a few money from crashed cars, it's the only possible solution for me. Odin, if it's in your possibilities to plug the car every night in your same place go for it, it might be a good solution (even 'cause up there it's a breezing part of Italy
krzychu.pl
How does dewasto
http://www.youtube.com/watch?v=Z8z2ZmDtgnY
Price 2500 euros is the cost of installation on the site Peugeot
in my village is a company that deals with installation and service dewasto,,, in a few days I will know exactly how much assembly to 406
http://autoport-jarocin.pl/montaz-systemow-webasto.html
How does dewasto
[youtube]http://www.youtube.com/watch?v=Z8z2ZmDtgnY[/youtube]
Great, isn'it?
Italian Price just to buy a brand new Power Unit is around 1350 Euros, but I suppose that a used one could have a good price. It might be interessant to know which model goes on 406, 'cause Webasto is usually already installed on various different kinds of vehicles, like Caravans Buses and Trucks (for last 2 I'm even talkin' about small sizes) as well. If ours come out to be a common model it might be easier to find it.
How does dewasto
Great, isn'it?
krzychu.pl
dewasto used in Poland can be bought for 100 euros ,,only needs to be fed like a car, or a petrol or diesel and dedicated to passenger car .
petrol
[img]http://fotka.406-klub.pl/pics/686919hjjj.jpg[/img]
diesel
[img]http://fotka.406-klub.pl/pics/347657fgfgfg.jpg[/img]
PSA diesel
[img]http://fotka.406-klub.pl/pics/491342fgjgfhjhj.jpg[/img]
used, of course, not new.
needed , water hoses, cables and controller.
Electric valve for water 60 euros
[img]http://fotka.406-klub.pl/pics/225757zawor.jpg[/img]
driver 120 euros
[img]http://fotka.406-klub.pl/pics/803643zaworplytka166.jpg[/img][img]http://fotka.406-klub.pl/pics/259870zaworplytka1.jpg[/img]
So even used it is not cheap [V]
petrol
diesel
PSA diesel
driver 120 euros
petrol
diesel
PSA diesel
driver 120 euros
Then, in the end, buyin' all parts might cost around 300 Euros for spare parts and then maybe around 150/200 euros more to set it up on the car. Not a few, but surely more possible than to go for a new one.
petrol
diesel
PSA diesel
driver 120 euros
Heater plugs, not glow plugs. You plug the AC in and they heat the water in the reservoir. Easy and cheap, common solution in USA and Canada.
krzychu.pl
